2000 Ford Explorer Broken Hose
159,000 MILES • 6 CYL • 4WD • AUTOMATIC
ZANEY1985
In the rear across the rear axle is a metal like hose for the brakes what is that part called
Jul 9, 2010 at 12:15 AM
  • 110,248 POSTS
The hose that runs across the axle is nothing more than steel brake line. It does come in different sizes, so take some of the original line with you.
Jul 9, 2010 at 2:37 PM
ZANEY1985
Ok so where should I go to get that hose so I can replace it and what is it called so I can tell the person I would be talkin to about it
Jul 11, 2010 at 6:32 AM
  • 110,248 POSTS
Hi:
Any parts store should have it. Take a piece of the old with you and just tell them you need steel brake line. Measure how much you will need because they come in sections and you will have to form them to fit. You don't want one too long or short.
Jul 11, 2010 at 4:14 PM
