Rear Coupler
90,000 MILES • 4WD • AUTOMATIC
AMANDA L JOHNSON
My rear coupler was replaced a few months ago at the dealer. Then my awd light came on and they said it was a sensor. Now they are saying my wiring harness has corrosion. Wouldn't that be seen during the first fix? My all wheel drive isn't working at all.
Dec 23, 2019 at 12:32 AM
  • 110,248 POSTS
When you say rear coupler, what specifically are you referring to? As far as corrosion, they should be able to clean it. Also, if it is corrosion, chances are the sensor is good.
Dec 23, 2019 at 3:27 PM
