rattling noise from right front wheel
93,450 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
BYGRAVE
there is a rattling noise coming from the right front wheel like a loose end and also from the right rear back wheel
Feb 8, 2016 at 11:49 AM
BYGRAVE
this sounds more like a loose or worn out end and a bushing noise ,especially at the rear
Feb 8, 2016 at 11:52 AM
CARADIODOC
  • 34,414 POSTS
This needs to be inspected at a tire and alignment shop. The people there are experts at finding the causes of noises, pulling, and bad tire wear patterns. This is especially critical with Ford front-wheel-drive cars as they have more trouble with steering and suspension parts separating than most other manufacturers. A light metallic rattle usually isn't a serious safety issue, but you want to know for sure. A separated ball joint or tie rod end can send you into the ditch or oncoming traffic.
Feb 8, 2016 at 11:58 AM
