rattling noise coming from my passenger side of my engine
2008 NISSAN VERSA
120,000 MILES • 1.8L • FWD • AUTOMATIC
MISSYHINKLE
  • 20 POSTS
i noticed earlier last week that when i start my vehicle i hear a rattling noise kinda hard to explain unless you actually hear but car but when i start it it rattle for a couple of seconds and then i i put it in drive and i accellerate just a little to get my car to move it more rattling as well yet agin for a couple of second then it stops i went to a mechanic and they said i need to replace my tension pulley so i replaced that they said it would stop to rattling well it didnt so my husband looked at my spark plugs they were bad i replaced all my spark plugs as well as my valve cover gasket because i found out i had oil on my plugs luckily i found that out right when the leak happened i have plenty of oil in my car so we are stumped as to what my problem with my vehicle is i also had my motor mounts check out by 2 mechanic shops my motor mounts are fine they are suggesting get a diagnostic test unfortunetly i dont have 89 bucks to get that done do you have any idea what may be the problem
Sep 22, 2014 at 8:47 AM
  • 110,244 POSTS
Is the noise coming from under the vehicle or the engine compartment? Have anyone checked for a loose heat shield on the exhaust or a catalytic converter that may have come loose inside?
Sep 22, 2014 at 10:35 AM
MISSYHINKLE
  • 20 POSTS
it sound like it is right under my engine itself on the passenger side i researched it online and the online source that i read sounds like a harmonic balancer but im not sure everyone i talk to i saying get a diagnostic on my car it only does it when i start my car and when my car is in park it stays rattling and also when i put it in drive as well and when i accellerate a little just so i can drive off out of my driveway it sounds like something scraping on the ground for just a second
Sep 23, 2014 at 12:13 AM
