The ignition lights are not working and is not tumbling
2WD • AUTOMATIC
DHANASARSOOBHAG
  • 25 POSTS
The ignition lights are not working and when the start key is turned, the engine is not tumbling. Basically there is no power in the ignition system.
Jun 13, 2014 at 9:36 AM
  • 110,251 POSTS
Have you checked the battery to make sure it is good, the terminals are clean and tight, and have you checked main fuses under the hood? Does anything electrical work?
Jun 13, 2014 at 1:19 PM
DHANASARSOOBHAG
  • 25 POSTS
the radio is getting power its just the ignition system battery is good
Jun 14, 2014 at 10:17 AM
  • 110,251 POSTS
Then it most likely deals with a main fuse under the hood.
Jun 17, 2014 at 1:53 PM
