Rainy or high humidity days will not start
123,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
CUERVO66
It will not start on rainy or high humidity days. I have drained the battery couple times and will not start, but in clear days no high humidity it starts right away with no hesitation.
Aug 29, 2018 at 6:07 AM
  • 110,248 POSTS
Based on your description, it sounds like an ignition problem. Basically, something shorts out, not allowing spark to get to the spark plugs. What you need to do is check to see if spark or fuel is missing to the engine so you can focus on one specific component. Take a look through this link. It discusses the possible reasons for a no start.
What I suggest is that when it will not start, you check specifically for spark to the plugs. Here is a link that describes how that is done:
Also, check to see if there are any trouble codes stored in the computer. Here is a quick video that shows how that is done. However, if there is a code in the system, it will remain for some time. Therefore, after this happens and then decides to start, take it to a parts store. Most will scan the computer for free.
https://youtu.be/b2IJGfImVvw
Let me know what you find when you check for spark.
Aug 30, 2018 at 11:20 AM
