Still overheats after replacing the radiator fan
153,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
GLOWE2000
I just recently got my radiator changed and my car still started to overheat afterward unless I have my A/C on. What can be the problem?
May 2, 2021 at 9:29 AM
  • 110,248 POSTS
If it doesn't overheat with the A/C is on, it sounds like the cooling fan isn't turning on. When you turn on the A/C, the fan will automatically turn on.
Can you tell me if it overheats at highway speed with the A/C off or does it seem to only happen if you are in stop-and-go traffic without the A/C?
Take a look through this link. It explains how the cooling fans are to work.
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
I need you to do me a favor. With the A/C off, pay attention to see if the cooling fans are turning on when the engine starts getting hot.
May 2, 2021 at 2:19 PM
