Overheating and antifreeze is leaking
2005 KIA SPORTAGE
136,000 MILES • AUTOMATIC
AMIR MALIK
My truck is over heating, and anti freeze is linking out slow on the ground. how can I tell if it is only a link thermostat or head gasket?
Feb 26, 2019 at 6:25 AM
  • 110,244 POSTS
The first thing you need to do is locate the leak. If the coolant is getting low, it will cause it to overheat. Take a look through these links.
https://www.2carpros.com/articles/coolant-leak-symptoms
https://www.2carpros.com/articles/car-is-leaking-coolant
Now, the easiest way to find a leak is by performing a pressure test. You will need a pressure tool to do it. Most parts stores will lend or rent one to you. Here is a link that shows how to perform that test:
https://www.2carpros.com/articles/radiator-pressure-test
The reason I recommend locating the leak first is simply because it could be something as simple as a loose hose. On the other hand, a bad water pump can leak too.
If you are concerned about a possible head gasket issue, here is a link that shows how one is tested. You can do this at home.
Do these things and let me know the results. Once we determine where the leak is, I can direct you through a repair.
Take care and let me know.
Feb 26, 2019 at 10:33 AM
