1999 Kia Sportage Overheating
83,500 MILES • 4 CYL • 4WD • MANUAL
EMTSVNLVS
Last summer I had the following done to my 99 Kia
Sportage. Water pump, timing belt, spark plugs, wires, air filter, fuel filter, thermostat replaced. I live in western Colorado and as our weather started to heat up so did my Kia so 2 wks ago took it back in to have the thermostat replaced again because it was fluctuating. Since getting it back it has started heating back up. It seems to do it only when I am sitting idleing. I can run on the hiway with the air on and it does not heat up. Once I get into town I shut the air off and just sitting at a stop light it will heat up. Any ideas? Thanks
May 28, 2009 at 1:15 PM
  • 110,248 POSTS
Are the cooling fans coming on? At highway speeds, air flows through the radiator from moving. When sitting still, the fans need to draw coolant through the radiator to cool it.
Jul 11, 2009 at 4:47 PM
JALAJANDA
My Car KIA Sportage 2000 EX like this trouble, and I just replace Motor Fan AC and repair Motor Fan Radiator, now I changes water coolant with distilled water but the problem not solve , could uyou tell me please how to solve my car problem, thank's
Jun 25, 2012 at 5:41 PM
