Duane Fulton says> The air cond does come on. I checked the fuse, relay, and put in a new temp. Sending unit. This weekend I'll check out the fan motor. Could be a bad wire somewhere.
Saturntech9 says>So when you turn the a/c on and you said it work's does your a/c condensor electric fan come on?All so if you have a kia sportage it say's you have a fan clutch and fan blade not a electric fan for the radiator. So are you talking about the electric fan for your a/c condensor not working?Or your radiator fan not working which is not electric if you do have the sportage model. Let me know.
Friday, June 18th, 2010 AT 3:53 PM
