Radiator fluid leaking
372,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
GREGGA604
My truck went into safe mode whole driving. I lost acceleration power assuming it was doing it to prevent further damage from happening. I let it sit I filled it with water but then I noticed it was leaking out underneath where the skid plate and oil pan is located. What could that be? My odb2 is not working due to a short so I cannot use diagnostics.
Jul 10, 2018 at 5:19 AM
AL514
  • 5,700 POSTS
Hello there, you should have the coolant system pressure tested. If there is a leak it will push out under pressure and be easier to find. Here is a guide to help with coolant issues:
https://www.2carpros.com/articles/radiator-pressure-test
Jul 10, 2018 at 5:28 AM
