Problems with humming sound
SKOOTER24
  • 275 POSTS
They did a alignment and Rotation so I’m guessing it probably is bent. They want cover it so is there anyway I can check the wheel alignment?
Friday, August 14th, 2020 AT 5:39 PM
STEVE W.
  • 13,965 POSTS
They should have a print out on the alignment. But unless it is eating tires I'm not sure I would replace it. What did they quote to replace it? A new beam is about $600.00 for the bare beam.
Friday, August 14th, 2020 AT 6:14 PM
SKOOTER24
  • 275 POSTS
I don't think she will replace it until it starts causing problems.
Friday, August 14th, 2020 AT 6:25 PM
STEVE W.
  • 13,965 POSTS
I wouldn't, If you get a chance take a close picture of the tires that were on the rear and post them. If there is weird tire wear it may show up, but unless it's way out replacing a set of tires every 20-30 thousand might be cheaper. You could also take it to one of the chain stores that does alignments and rotations cheap and get a printout on it's current condition. Here there are places that do them for about $50.00 and that would give you a better idea of the problem, unless they give you a print out, if they do post it and we can look at what it might do if it's bad.
Friday, August 14th, 2020 AT 6:38 PM
SKOOTER24
  • 275 POSTS
I will do that then I'll take pictures of everything and send it when I get a chance. Will this question be still up if I send them?
Friday, August 14th, 2020 AT 6:42 PM
STEVE W.
  • 13,965 POSTS
Yep, just log in and it will still be here, forever, or at least until the internet finally crashes.
Friday, August 14th, 2020 AT 8:41 PM
