Problem with idling low and dying when stopped
1994 MERCURY COUGAR
88,000 MILES
JFOLSTAD
I need to know what the part is called that sits on top of the engine and carries air from the intake. It is the plastic piece that covers the engine and has the V8 4.6L badging on it. Any help is appreciated.
Thanks!
Nov 4, 2013 at 12:32 AM
  • 110,240 POSTS
Are you referring to the intake manifold? Also, have you checked for vacuum leaks and the idle air control valve (IAC)? The IAC is responsible for maintaining the engine idle speed.
Nov 4, 2013 at 12:40 AM
JFOLSTAD
Yea i guess it is, i took it in for a diagnostic, (check engine light) and they said that part was "broken up inside" he wanted to call it a upper engine cover, and that it was all busted up and they couldnt do a test til that was replaced.,, sounded fishy, it was at the end of the day and they got me for $90 diag fee. i dont hear any air under hood tho. if its leaking i cant hear it. or see/feel it
Nov 4, 2013 at 3:19 AM
  • 110,240 POSTS
If the check engine light was on, did they tell you the trouble codes they got?
Nov 4, 2013 at 11:43 AM
JFOLSTAD
He said they couldn't even do it because it failed a smoke test so bad
Nov 4, 2013 at 11:45 AM
  • 110,240 POSTS
I would recommend a second opinion. Not saying that they are wrong, but they should still be able to pull a code from the computer regardless if there is a leak.
Nov 4, 2013 at 11:51 AM
