1994 Mercury Cougar hard start when cold or wet
1994 MERCURY COUGAR
140,000 MILES • 6 CYL • 2WD • AUTOMATIC
KARL59
had egr and map sensors replaced due to check engine light also new battery. car runs alittle rough but in mornings hard to start and when started and when you go to restart after it warms up no problems
Dec 4, 2008 at 12:56 AM
  • 55,432 POSTS
Hi, check the fuel pressure regulator, also check the ECM engine temp sensor, its sound like it could be bad.
Dec 5, 2008 at 4:22 PM
KARL59
would either if those things make the check engine light go on
Dec 5, 2008 at 8:00 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, both would throw the engine light. If your engine light is on then you should run a diagnostic scan and get the codes. This will make it much easier to diagnose the situation. Most auto part stores such as AutoZone or Advance Auto Parts will run a test for free if you do not have a scanner.
Dec 5, 2008 at 8:11 PM
KARL59
i ran the codes and the light is now off but still have hard time starting when it rains or snows out
Dec 6, 2008 at 8:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
What code numbers appeared??
Dec 6, 2008 at 8:08 PM
KARL59
i had the codes before but they were for the low voltage on egr valve sensor and maf sensor
Dec 7, 2008 at 10:29 PM
