Possible Choke Problem.
SGGILMO
  • 5 POSTS
I have a 1986 Mercury Cougar with the 3.8L CFI motor and the thing will not Idel before being warmed up even when it's 90 degrees out. When I got the car I was told it had a choke problem. I was just Woundering if that is what it is and if so what would need to be done to fix it. Thanks.
Nov 24, 2007 at 12:34 AM
  • 75,988 POSTS
Its a fuel injection system it has no choke-find the coolant temperature sensor and test it
Nov 25, 2007 at 9:42 AM
SGGILMO
  • 5 POSTS
Well that's good to know. how would I go about testing that. Also What will I be looking for when I yest it. I'm prety new to car mechanics but I like to do as much as possible myself. Thanks
Nov 25, 2007 at 10:14 AM
  • 75,988 POSTS
Do you have a book for this vehicle?
Nov 25, 2007 at 10:55 AM
SGGILMO
  • 5 POSTS
Yes and no. The Heynes manual came with the car but it is very old and is missing many pages. I should problay get a new one. Also I have a pc program that I bought a long time ago for my grand am when it was leaking. It covers anything from 1983 to now and I decided to see what it would say just by my symptems and it told me to check the "cold start valve" or someting like that. Does that exist and if so would that have anything to do with my problem sence it does not idle only when it's cold?
Nov 26, 2007 at 12:11 AM
  • 75,988 POSTS
The CSV only works for a few secs that's it, you can check it's resistance.
Nov 26, 2007 at 1:06 AM
SGGILMO
  • 5 POSTS
[quote:710b54f014="rasmataz"]Its a fuel injection system it has no choke-find the coolant temperature sensor and test it[/quote:710b54f014]
Well I just repaced that sensor and it fixed my problem. thanks bud.
I got one more problem to fix though. When the car idles it has a slight stumble every 8 to 15 seconds. Any idea what it could be? I was thinking a bad plug.
Thanks again.
Nov 29, 2007 at 11:50 AM
