problem while dirving
53,000 MILES • V6 • 4WD • AUTOMATIC
ELIE ELYAS
while pressing the acceleration pedal the car did not accelerate it was moving slowly and suddenly stopped and AT/Oil sign appeared on the dashboard. then i shifted the gear to park and started the engine everything was normal again (i checked the engine and transmission oil they were within normal range).
I also have another problem with the steering, it is very difficult to steer the wheels after fixing steering oil leakage.
Jun 28, 2017 at 7:05 PM
HMAC300
  • 48,601 POSTS
have it scanned for codes auto parts does for free if it continues a mechanic will need to scan it as it may be a module that auto parts scanners do not work on. you may have air in system for power steering check for low fluid. tires inflated properly. to get air out turn to lock one way hold for thirty seconds then other way. repeat five times.
Jun 28, 2017 at 10:52 PM
