Will not start
60,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
TEDCOHEN
Car in Parking gear as usual I turn the key and the starter engages strongly.
The engine will not start. Battery is about 1 year old. Gas tank is more than half full, about 9 gallons.
Jun 26, 2021 at 6:23 AM
  • 110,248 POSTS
If the engine cranks and doesn't start, chances are either fuel is an issue or ignition spark. The vehicle doesn't have many miles, so I don't suspect anything serious.
First, take a look through this link. It discusses the most common causes of a crank no start condition.
Now, the easiest thing to do to determine if it is a fuel or spark problem is this. See if the engine starts for a couple of seconds using starting fluid. If it does and then stalls, we know it is fuel-related. If it doesn't then it's likely not getting ignition spark to the plugs.
If you are uncomfortable using starting fluid, here are two links. One explains how to check for spark and the other fuel pressure.
Take care and I'll watch for your reply.
Jun 26, 2021 at 1:47 PM
