PROBLEM ON AC AND GEAR
1999 HYUNDAI SANTRO
46,000 MILES • 4 CYL • FWD
VAMSHI SAINI
My car has a problem with the Air conditioner. When I start the car the temperature rises by its self even if I am not accelerating. The air conditioner does not cool the car. A mechanic told me that one of the components of the air conditioner needs replacing. Is that true? I have checked all of the fuses and they are all good. Another problem I am experiencing is when traveling in fifth gear it trips and goes into neutral. What could be causing this? Any ideas?
May 17, 2016 at 7:58 PM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
have a local pro check to see if it has correct Freon amount in system. then have them check adjustment of shifting linkage to see if bad cable s if any otherwise it may be a bad synchro/shift fork inside transmission.
May 18, 2016 at 6:07 AM
