car heating up in ac and non ac
8 MILES
ANURAGTODI
A few weeks ago my car temperature raised max and smoke was their all over the bonnet.Later on ii checked there were leakage's in the radiator..I fixed it after that also the car was heating up..then I again checked it and changed the gasket coolant and engine oil..Later on the car again heating up..so I changed the water pump as well ...I get a cremation color substance nowadays in coolant box and also a few of them on radiator after open in it...the fan also works fine..dont Know what to do..Please help...asap
Oct 1, 2013 at 12:46 AM
WRENCHTECH
  • 20,758 POSTS
If you're getting oil mixed with the coolant, then you have a serious issue than you need to find. That could be a leaking oil cooler, cracked head or blown head gasket. I suggest you tow it to a professional right away while you still might have a chance to save the engine.
Oct 1, 2013 at 1:06 AM
