Pressing brakes turn signal illuminates
44,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
MASSIVEDYNAMIC
When I press the brakes the passenger side turn signal illuminates as if it were a brake light.
Jun 14, 2020 at 4:09 PM
MOTOR MASTER
  • 279 POSTS
Hello my name is Dave.
It sounds like the most likely cause is a bad bulb, my data shows that to be a dual element light bulb and what can happen is one of the elements brakes and touches the other, causing that one to back feed into the turn signal circuit. Usually this will also cause the other brake light to flash with the the turn signal, in your case the driver's side brake light would flash with the passenger's side turn signal. Please keep us up to date on your progress and thank you for using 2CarPros.
Jun 14, 2020 at 9:12 PM
