2002 Dodge Ram rear turn signals
90,000 MILES • V8 • 4WD • AUTOMATIC
AIRLOP
both my rear turn signal work sometimes. I am assuming that it is a ground issue. This started after towing a trailer. Where is the ground located for the rear turn signals? Thanks.
Sep 17, 2010 at 12:14 PM
  • 110,245 POSTS
If you have a trailer hitch and wiring, start there. Follow the wiring to where it is spliced together. At that point it is my guess you have a loose wire or connection. Also, often times the ground is right on the frame for the trailer.
Sep 20, 2010 at 5:44 PM
