Intermittently while driving a wrench appears on my dash and says powertrain malfunction and the car goes into limp mode
26,000 MILES • 4WD • AUTOMATIC
KEMARIA
So I took it to an AutoZone to have them run a diagnostic on it and it came back as a sensor issue. they told me to disconnect the negative battery terminal and reconnect. it is this what I should do?
Apr 5, 2021 at 12:40 PM
  • 110,248 POSTS
I'm not sure if that will help. What code was found? What sensor was an issue? As far as sensors, usually disconnecting the battery won't change what they are doing.
I hope to be honest, this vehicle should still be under the basic 3/36K warranty. Everything other than maintenance items is covered. Also, based on the sensor, it could be covered for much longer.
Let me know as much as you can or if you have other questions.
Apr 6, 2021 at 2:09 PM
  • 55,612 POSTS
This guide can help explain limp mode and the guide before can help you find the codes.
https://www.2carpros.com/articles/reduced-power-limp-mode
and
https://www.2carpros.com/articles/checking-a-service-engine-soon-or-check-engine-light-on-or-flashing';
Apr 7, 2021 at 11:16 AM
