power windows will not roll down
153 MILES • 3.2L • V6 • AUTOMATIC
BPUCKETT
i have replaced the main switch on the drivers side door and then the power window circuit breaker fuse in the fuse panel and the power window relay and i still can not get the windows to roll up or down what can be done to fix them next
Sep 10, 2014 at 8:28 AM
CARADIODOC
  • 34,413 POSTS
The proper thing to do is diagnose the problem first, then replace parts, but if you have used parts available, replacing them is a quick and easy test. Next I'd be looking for broken and frayed wires between the door hinges.
For future reference, when you have just ONE window that doesn't work, even if it works from one switch, (driver's or passenger's), but not both ways with the other switch, EITHER ONE could be defective. Both switches have four sets of contacts inside. Two are used when the switch is pressed and the other two are used when the switch is released and the OTHER switch is being activated. Any one of those eight sets of contacts can prevent the window from going one way
Sep 10, 2014 at 9:50 AM
