power Windows stopped working all at the same time
1995 HONDA PASSPORT
140,000 MILES • 3.2L • 6 CYL • 4WD • MANUAL
IMPOSSIBLE12
  • 12 POSTS
I removed the master power switch and went to a Pick & pull junk yard, found 3 Honda Passports, same year as mine. I removed the switches and tried them on my car...none would work. Took out the 30amp power window fuse(this fuse is black with a red button that you can push in but does not stay in) . I got 3 30amp fuses from the same cars and tried them...still no luck. I tried to get to the wires inside the door hinge which are inside a boot, I can pull out each side of the boot but have no room to get to the wires. Now what should I do next? Remove the door panel? Because there is no way to get to the wiring by the hinge. Thanks, Marie
Jan 16, 2015 at 10:33 AM
HMAC300
  • 48,601 POSTS
ife button won't stay in there is a short someplace and it would be to the switch I imagine. there is relay in right side of dash above the kick panel try another one or see if circuit breaker button will stay in if not check blue wire leading to switch if early production and green red which goes to all the switches if late production. If something has been recent ly installed in dash like a switch or something take the screws out as it probably cut in to the harness and is causing the problem.
Jan 16, 2015 at 10:29 PM
