Power steering stiff when first starting the car
212,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
JEFF HERMAN
  • 486 POSTS
Upon start up recently the power steering has been stiff. When warmed up it's better. No leaks, belt is tight, no noise from pump. Would changing the fluid help? Hope it isn't the rack. I haven't put one in since my 1983 Scirocco.
Mar 11, 2021 at 10:51 AM
  • 110,248 POSTS
Is the fluid clean and full? Hydraulic fluid will expand when it gets hot, so there is a chance it is low. As far as the rack, usually, you will feel a binding when they go bad.
Take a look through this link and see if anything helps:
https://www.2carpros.com/articles/power-steering-problems
Let me know if that helps or if you have other questions.
Take care and God Bless,
Mar 11, 2021 at 11:59 AM
JEFF HERMAN
  • 486 POSTS
Power steering fluid is full when cold and I don't see any leaks, but I'll look at everything closer tomorrow. Have you ever heard of using seafoam Trans Tune in there to unblock the valves in the rack?
Mar 11, 2021 at 12:03 PM
  • 110,248 POSTS
I haven't heard of that. There really aren't valves in the rack. Operation is based on pressure variation.
Mar 11, 2021 at 1:24 PM
JEFF HERMAN
  • 486 POSTS
Okay, I'll keep you posted as to what I find out. Thanks for your help.
Mar 11, 2021 at 1:25 PM
  • 110,248 POSTS
You are very welcome. I look forward to hearing what you find. I'm interested in knowing.
Mar 12, 2021 at 9:41 AM
