Power Steering
183,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAVID NICOLAS
When turning the steering wheel a whining sound occurs. On my last oil change I asked for a power steering fluid check, which came back okay. Do I need the lines to be bled or is the whining a sign of something wearing out?
Mar 10, 2017 at 3:59 AM
HMAC300
  • 48,601 POSTS
it may be the power steering pump making the noise. due to your mileage you might try changing the fluid otherwise a mechanic will have to check to see if it is the pump valve or not.
Mar 10, 2017 at 4:11 AM
DAVID NICOLAS
Thank you so much, and so quick. I was thinking a pump problem. How urgently should I have the pump checked?
Mar 10, 2017 at 4:18 AM
HMAC300
  • 48,601 POSTS
it is not really urgent as a lot of pumps will whine until the car dies if you have added something like the wrong fluid at one time that will do it as well . Maybe next time you take car in for service unless you lose your steering which is unlikely.
Mar 10, 2017 at 7:31 AM
