Power Loss
365,000 MILES • 3.0L • 6 CYL • TURBO • 2WD • MANUAL
MOLOGIES
My bakkie loses power going uphill. Air filter and diesel filters have been changed but that is not the problem. What should I look for to find the problem?
May 3, 2022 at 5:33 AM
BORIS K
  • 836 POSTS
As this vehicle is diesel it should be fitted with a DPF. These can become overloaded with soot which in turn can cause back pressure issues in the exhaust system. This in turn can lead to low boost pressure and reduced engine power.
Another issue can be the SCV, suction control valve, at the rear of the high-pressure fuel pump. These can fail and cause reduced fuel pressure in the rail which in turn can cause loss of engine power. See images below
There could be a host of issues which can cause loss of engine power such as lack of boost, blocked fuel filter, blocked air filter, contaminated intake manifold, sticky EGR valve and the list goes on.
Have you checked the ECU for any fault codes? This will be the best way to start.
How to carry out a CAN scan:
Please let us know how you get along.
Cheers, Boris
May 4, 2022 at 12:28 AM
