Possible Pinion Replacement
69,000 MILES • 6.0L • V8 • 4WD • AUTOMATIC
CHARLES MCKINNEY
I have a 2500 Hd 6.0 gas truck. The transmission shifts great but while In first gear it makes a whistle sound then in second it gets more faint, when third hits it is gone. It sounds as if it is located in the transmission, but I have read possible rear pinion.
Feb 23, 2017 at 5:04 AM
  • 31,937 POSTS
i doubt that it will be in the drive line, but it would not hurt to inspect uni's and pinion nuts are tight and there is no movement. this sound like a transmission or transfer noise. best to get a mechanic to road test as listening to these noises are a far better way to start a diagnosis. just make sure that the oil levels are okay and you do not have contaminants in the oil. if you have not done so in some time, change the oils and check oil oil for metal discoloration and shavings on the drain plug. metal contamination in the oil can look like a silvery sheen in the oil.
Feb 23, 2017 at 8:14 PM
