Possible blown head gasket
243,000 MILES • 4.6L • 6 CYL • 2WD • MANUAL
SIZEMORE_215
Truck got hot shut down no oil. Put oil in it got home changed the thermostat. Had a 195 I think put a 160 thermostat in it. When replacing it I did not clean it good enough and water was coming out of the housing bad. Cleaned it up and no more water came out since. Now when I drive it, it will get hot after about fifteen to twenty minutes and after that I will begin to lose power. Also, the radiator cap will begin to squeal hearing the pressure come out sounds like. Had only happened once this is the day after I replaced it and I was coming home from work. Did not have coolant used water and during all this the oil cap is milky and dipstick oil seems fine just a little bit of water on it (tiny bit). I can also look down the oil cap and see some water on rocker arms. no leaks come out of anywhere on this truck.
Jul 5, 2017 at 11:40 AM
CJ MEDEVAC
  • 11,000 POSTS
Sorry,
Really sounds like a head gasket issue.
A cooling system pressure test will probably verify it.
Let us know the test results.
The Medic
Jul 5, 2017 at 11:55 AM
RENEE L
  • 1,260 POSTS
Hello SIZEMORE_215,
Here is a great article from the site for pressure checking your cooling system. This article features step by step instructions with pictures and a video.
https://www.2carpros.com/articles/radiator-pressure-test
If you need further assistance please feel free to come back to 2CarPros we are always happy to help.
Have great rest of your day!
Kindest regards,
Renee
Admin
Jul 7, 2017 at 5:38 AM
