shaking in the front
PONTIAC TRANSPORT
ROCKINROSS4EVER
i have a 1998 pontiac transport.It shakes on the right front side and i noticed that my tire is wearing on the outside of the tire. It stops under ecceleration and braking is it allingnment or is it the suspention, like cv joints or something in that feild please help thanx
Apr 18, 2007 at 12:28 PM
SERVICE WRITER
  • 9,123 POSTS
There may be a domino affect here. A loose steering or suspension part will casut the alignment to be out and cause the tire to wear abnormally.
The shake may be from the wheel being out of balance from wear, a loose steering part, a bad tire or a bent rim. Although it is possible the the cv joint is bad, it could cause a shake but not a tire wear problem.
Apr 18, 2007 at 3:09 PM
