1998 Pontiac Transport Front Shake
ROCKINROSS4EVER
i have a 1998 pontiac transport.It shakes on the right front side and i noticed that my tire is wearing on the outside of the tire. It stops under ecceleration and braking is it allingnment or is it the suspention, like cv joints or something in that feild please help thanx
Apr 18, 2007 at 12:28 PM
SERVICE WRITER
  • 9,123 POSTS
There may be a domino affect here. A loose steering or suspension part will casut the alignment to be out and cause the tire to wear abnormally.
The shake may be from the wheel being out of balance from wear, a loose steering part, a bad tire or a bent rim. Although it is possible the the cv joint is bad, it could cause a shake but not a tire wear problem.
Apr 18, 2007 at 3:09 PM
Suggested Repair
Inspect the right-front steering and suspension for looseness, then check alignment, wheel balance, tire condition, and the rim. A bad CV joint can cause a shake but would not explain the outer tire wear.
Conversation Summary
The owner of a 1998 Pontiac Transport reports a right-front shake and outside tire wear that stops during acceleration, and asks whether alignment, suspension, or a CV joint is responsible. The expert says a loose steering or suspension part can throw off alignment and cause abnormal wear. The shake may come from an unbalanced worn tire, a loose steering part, a bad tire, or a bent rim; a CV joint could shake but would not cause the tire wear.
