1998 Pontiac Transport Engine Mount Torque Strut Brackets
BOBG
  • 1998 PONTIAC TRANSPORT
  • 6 CYL
  • FWD
  • 110,000 MILES
I need to remove the engine mount torque strut bracket on the passenger side. I found only two bolts, the upper bolt and the one on the far left I can't find any others, even when I use a mirror to inspect the bracket. The bracket won't budge. Any idea where the bolt(s) is located?
Sunday, January 13th, 2008 AT 4:00 PM
BOBG
I figured it out. Two bolts from the AC compressor must be removed, and a third bolt must be backed out about 6 turns. The repair manual does not mention this at all.
Saturday, January 26th, 2008 AT 9:16 PM
