The window has a broken bar under the window that is connected to the two arms that push the window up and brings it down. Because of this the window goes up and down at a angle and will not close. I tried to remove the assembly which has the speaker, window drive motor ,window spring and connectting rods for door lock and door handle. I could not get the whole window and rails out the opening on the inside of the door. Can this be done or do I have to buy a door with everything inside?
Apr 24, 2010 at 4:24 AM
