Please help!
Ryan
El Paso, Texas
Do not remove the thermostat unless testing shows it is stuck closed. Confirm the cooling fans and fan relay work, then verify the water pump is circulating coolant and the thermostat opens. Gauge cycling can indicate trapped air even without visible coolant loss. If the pump, fans, and thermostat are working, check for a blocked cooling passage or an inefficient radiator. The slipping sensation is likely unrelated unless overheating is causing power loss.
A 1997 Pontiac Transport with 161,000 miles overheats after 15-20 minutes despite a new radiator, radiator cap, intake gasket, and heater core. The expert said removing the thermostat will not solve overheating unless the thermostat itself is faulty, and listed fans, pressure, coolant condition, belt tension, blockage, and the water pump as possible causes. After a mechanic checked the fans and repaired a relay, the van still overheated and the gauge cycled around 210 degrees. The expert attributed that cycling to possible trapped air or a thermostat issue and advised confirming water-pump flow; if flow, fans, and thermostat are OK, look for an obstruction or poor radiator efficiency. The reported slipping was considered likely unrelated.
