Is it possible that there is a wire broken or maybe something attached to timing gear that isnt sending signal or? Problem is after I get the PCM reset at the dealer it will run fun for a while, then after a week or 2 it starts quitting on me again. Also, I replaced fuel pump 3 times and relay and installed a new strainer. And when the van warms up it runs like crap (separate issue I think), it started that after I replaced the TPS. I think I may have torn up my MAF unit not sure. Anyway the camshaft sensor has been the main problem before anything else.
HELP!
Thanks
mobbeh
Monday, January 16th, 2006 AT 3:55 PM
