2002 Pontiac Sunfire Steering Creak
ROUSHMUSTANG39
Hello:
I recently bought a 2002 Sunfire with 59000 miles that has a creeking noise and feel that is being transmitted back through the steering wheel and brake pedal. Any ideas ? The last owner just had all 4 struts replaced and I was wondering if this could be the front strut mounts ?? It only does it while turning in either direction at slow speeds. It will not do it while traveling at higher speeds.
Any ideas would be grealy appreciated... My next turn will be to bring it into a shop for inspection, but if anyone could help I will check it out first myself....
Thanks !!
Apr 6, 2007 at 12:48 PM
BOOTDOG
  • 665 POSTS
i would check those strut mounts. if they're not seated right or worn, that could cause a noise problem.
Apr 6, 2007 at 2:36 PM
Suggested Repair
Inspect the front strut mounts for wear or improper seating, which can cause noise after strut replacement.
Conversation Summary
A 2002 Pontiac Sunfire with 59,000 miles creaks and transmits a feel through the steering wheel and brake pedal only when turning at slow speeds, not at higher speeds. All four struts were recently replaced, and the owner suspects the front strut mounts. The expert recommends checking the strut mounts for improper seating or wear.
