1999 Pontiac Sunfire Fan Won't Turn On Fix
JETSTREAM
  • 6 POSTS
I have a 99 Sunfire 2.2L no A/C, Auto and 105,000Km.
The cooling fan is not turning on at all. The fuse, the relay, the coolant temp sensor, and the fan itself have been checked and work perfectly. I have also checked the circuits for the coolant temp sensor and the fan and they to check out okay.
However when I unplug the coolant temp sensor (with the engine running) the cooling fan comes on right away. My guess is the PCM.
Anyone have any other ideas?
Sep 1, 2007 at 4:37 AM
  • 75,988 POSTS
The PCM commands the cooling fan by grounding the relays. Its a lot cheaper just to hot wire the fan motor than to replace the PCM by using its power source and ground.
Good luck.
Dec 9, 2018 at 12:40 AM
JETSTREAM
  • 6 POSTS
Thank you for your quick response!
I take it from your reply, that the PCM is the problem then. Thanks for the tip on hot wiring the fan but I have sourced a PCM from a wrecker for very cheap ($60.00 and tested).
Suggested Repair
The PCM grounds the cooling-fan relay. Since the fuse, relay, sensor, fan, and circuits already tested good, either replace the PCM or hot-wire the fan using its power and ground as a cheaper workaround.
Conversation Summary
A 1999 Pontiac Sunfire 2.2L overheats because the cooling fan never runs, even though the fuse, relay, coolant temperature sensor, fan, and related circuits check out. Unplugging the sensor with the engine running turns the fan on immediately. The expert explained that the PCM commands the fan by grounding the relay and suggested hot-wiring the fan as a cheaper alternative to PCM replacement. The owner planned to install a low-cost used PCM.
