Is 220 kmh the top out for the speedometer? You can try disconnecting battery and reconnecting after a few minutes, this will reset the gauges. It will also reset your radio stations though so be sure you have them written down if you have any preset.
SPONSORED LINKS
Wednesday, November 13th, 2019 AT 5:58 PM
(Merged)
MECHANIC
I'm an expert in here
Look at my 1st post then you'll know what is a VSS furthermore I request you do a refund I don't need this Bye and Good luck I tried helping
(Merged)
DOUG 57
MEMBER
I tried to disconnect battery it is still at 220km
(Merged)
BLUELIGHTNIN6
MECHANIC
If equipped, is the tachometer (RPM gauge) working and is transmission shifting fine? Get a magnet and stick it in front of the speedometer needle, very slowly drag it back to the 0 mark.
(Merged)
