2003 Pontiac Sunfire installing a Subwoffer
AMY1980
2003 Pontiac Sunfire 4 cyl
HI there, I have an amp that i have wirted through the back speakers and i want to instal an subwoffer as well, i was wondering what fuse i should route the subwoffer through? the last time that i tried this i killed the battery so i am know that i need a fuse that the power gets cut when the engine is turned off can you help me please??
Thank you..
Amy Meredith
May 27, 2009 at 9:02 AM
RHALL77
  • 3,361 POSTS
are you using a aftermarket radio for this. if you are use the remote wire to turn on the remote wire for the sub
May 28, 2009 at 8:59 AM
AMY1980
no i am using the original car stereo.
May 28, 2009 at 11:57 AM
RHALL77
  • 3,361 POSTS
then you would need to hook in a switch with it.
May 29, 2009 at 1:18 AM
