HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Pontiac
Sunfire
Engine
Symptoms
Not Running
2001 Pontiac Sunfire WONT START
MOLLY MUSSELMAN
MEMBER
2001 PONTIAC SUNFIRE
4 CYL
2WD
AUTOMATIC
100,000 MILES
THE WINDOWS GO UP AND DOWN BUT THE ENGINE WHEN TURNING THE KEY OVER JUST CLICKS. THE RADIO ALSO WORKS. IT JUST WONT START.
Sunday, June 8th, 2008 AT 11:34 PM
BLACKOP555
MECHANIC
First thing to do is check and clean the battery terminals of the battery. Next make sure the battery is fully charged.
If problem still persists either the starter has failed or is jammed in the flywheel or more likely the solenoid has failed.
SPONSORED LINKS
Monday, June 9th, 2008 AT 8:02 AM
Please
login
or
register
to post a reply.
Related Engine Not Running Content
2001 Pontiac Sunfire Car Loses Power, Will Not Start
Electrical Problem 2001 Pontiac Sunfire 4 Cyl Front Wheel Drive Automatic 72k Miles For The Last Few Weeks, The Car Has Been Losing...
Asked by
erhamlin
1 ANSWER
2001
PONTIAC SUNFIRE
VIDEO
How to fix an engine that wont start
Instructional repair video
GUIDE
Engine Not Starting
Over the past 20 years at 2CarPros we have identified the top problems that are easily fixed. This guide can save you a trip to the repair garage or calling a tow truck and...
Car Will Not Start
Just Replaced The Water Pump And Head Gasket Because Of Overheating Issues. Two Days Ago I Noticed The Ac Plug Had Not Been Plugged In After...
Asked by
ericasimmons904
1 ANSWER
1 IMAGE
2001
PONTIAC SUNFIRE
2001 Pontiac Sunfire Car Will Not Start When Is Is...
I Have Replaced The Engine, Transmission, Fuel Pump, Fuel Filter, Fuel Relay And Injectors, When Driving The Car It Runs Fine With No...
Asked by
Lamont2010
1 ANSWER
2001
PONTIAC SUNFIRE
Will Not Start After Running Out Of Gas
Ran Out Of Gas, Put Gas In And Car Still Will Not Start.
Asked by
coriander
2001
PONTIAC SUNFIRE
2001 Pontiac Sunfire Will Not Start!
Had The Car For 3 Months Now. Has Been Starting And Running Fine Daily. A Few Weeks Back The Car Wouldn't Start. Someone Fiddled With...
Asked by
DaveSw
2001
PONTIAC SUNFIRE
VIEW MORE
SPONSORED LINKS
Crankshaft Sensor Symptoms
Crankshaft Sensor Replacement
Online car repair manuals
