Welcome to the forum. You need to check for voltage and ground at the fuel pump relay, try to see what is going on? Engine crankiing, do you have primary voltage at the injector/s? If the computer doesn't see an rpm signal, it won't ground the injectors or fuel pump relay, engine cranking. I believe the crank sensor is ok, because you have spark during cranking.
SPONSORED LINKS
Friday, November 20th, 2009 AT 10:50 AM
