I have come up with code P0300 misfire detetcted by pcm. I have changed, camshaftsensor, crankshaft sensor, coils are firing, pump sounds likes running, smell gas, I have completed a compression tets on the engine 1 cly -60psi, 2cly-40psi, 3cly-60psi, 4th clyis 120psi. I'm not sure? Is it the timing chain, but heard they are dont uselly dont break that quickly, in the past it heated acouple of times, changed coolant sensor, fan relay, thermosatate. It seem to work for a bit overheated agin and wont start.
what is your suggestion?
SPONSORED LINKS
Monday, April 20th, 2009 AT 12:33 PM
