1999 Pontiac Sunfire re: car intake question
SUNFIREGUY98
Engine Performance problem
1999 Pontiac Sunfire 4 cyl Front Wheel Drive Manual 190 k miles
thanks for your response, i appreciate it. by cold outside i mean its winter and temps are around -10. i was wondering if that winter air is too cold coming through a tornado filter and wouldnt be very good for the engine. so i would be better off with the stock box you say? even if it is a bit more restrictive?
Feb 25, 2008 at 7:13 AM
2CARPRO JACK
  • 11,533 POSTS
If you like the intake noise and just a few more hp, then by all means go for it. The PCM will adjust for the air temp outside.Sounds as though you may need a fuel additive to keep it from freezing
Feb 25, 2008 at 7:16 AM
SUNFIREGUY98
hey thanks i appreciate your help. no i dont think it will freeze up, i havent used it in the winter actually so i dont have any problems with the temp. i was just curious if the cold air would have any adverse affects. thanks again.
Feb 25, 2008 at 7:19 AM
2CARPRO JACK
  • 11,533 POSTS
engines make the best power with cool slightly damp air.
Feb 25, 2008 at 7:32 AM
