1999 Pontiac Sunfire headlights
RAGEBLITZ
  • 1999 PONTIAC SUNFIRE
Electrical problem
1999 Pontiac Sunfire Two Wheel Drive Automatic
I need to know where the low beam relay is on a 1999 pontiac sunfire
Thursday, June 10th, 2010 AT 12:29 PM
SATURNTECH9
  • 30,869 POSTS
I emailed you the information you need to your personal email.
Thursday, June 10th, 2010 AT 12:46 PM
RAGEBLITZ
Thank u for sending me the images I can't seem to read the images well the words on the images to know exactly where the low beam relay is so I can repair it
Thursday, June 10th, 2010 AT 2:52 PM
SATURNTECH9
  • 30,869 POSTS
Do you have the se or gt model?I didn't see a low beam relay in the wire diagram. So I take your low beam head lights are inop?Did you check all the fuse's?Did you make sure you checked power and ground to each head light low beam?Checking them seperatley?Like if you were using ohms you check the ground side of each low beam blub to ground and see if it is 2 ohms or less. Then leave the the ground to the meter attached and change to volt's and check the power side. Let me know what you find.
Thursday, June 10th, 2010 AT 3:18 PM
RAGEBLITZ
I have triple bulbs its one bulb that does daytime, low, and high so thats kind of hard to do, and there should be a low beam relay so says the merchants mechanic so if I find that I can repair it and it should work if not its the switch
Thursday, June 10th, 2010 AT 3:22 PM
SATURNTECH9
  • 30,869 POSTS
Do you have the se or gt?Let me know and I will send you a list and location's of all your relay's.
Thursday, June 10th, 2010 AT 3:46 PM
RAGEBLITZ
Se
SATURNTECH9
  • 30,869 POSTS
I emailed you a list of all the relay's and there location's I also blew up the head light wire diagram it's a two parter now.I just don't see that low beam relay in the list of relay location's or in the wire diagram you can look for your self I just don't see it.
Thursday, June 10th, 2010 AT 4:02 PM
