why does the fan only work when the air conditioner is on? If you turn off ac it overheats
Tuesday, April 21st, 2009 AT 7:35 PM
BLUELIGHTNIN6
MECHANIC
First ensure coolant is at proper level in radiator. If OK, inspect cooling fan relay (located in underhood fuse/relay center). Let me know results and I will follow up.
Thanks for using 2CarPros. Com!
SPONSORED LINKS
Tuesday, April 21st, 2009 AT 9:20 PM
CARLENEM
MEMBER
II don't know how to check the relay to see if its good or not? The electic fan does come on, and the temp stays normal as long as you have the air conditioner on. As soon as you turn off the ac the fan doesn't come on any more. So, now what? Any kind of help would be appreciated.
Tuesday, April 21st, 2009 AT 11:09 PM
BLUELIGHTNIN6
MECHANIC
Follow the link below to learn how to check a relay..
