1998 Pontiac Sunfire no electrical components
150,000 MILES • 4 CYL • FWD • AUTOMATIC
MBARTON15
Vehicle runs/drives fine, but I have no power to radio, headlights, horn, acc., the speedo, tach, and guages do not work . The only thing that works are the blinkers, and brakelights. I can't find a fuse that is out in either of the boxes.
Oct 25, 2010 at 2:03 AM
  • 75,988 POSTS
The headlights should come on without the ignition switch or key being in the run position-inspect and test all the fusible links, power starts here before it goes in the vehicle
Oct 25, 2010 at 7:26 AM
