1998 Pontiac Sunfire
1962GATOR
  • 1998 PONTIAC SUNFIRE
Electrical problem
1998 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
i have had the starter bench checked and it work fine, battery is only a month old alt was just replaced about a month ago, and the car will not start, could the problem be with my ignition switch, please advise I am at my wits end.
Monday, October 11th, 2010 AT 10:48 AM
WRENCHTECH
  • 20,761 POSTS
What DOES the car do?
Monday, October 11th, 2010 AT 10:58 AM
1962GATOR
Its does nothing all warning light and the dashborad light up, I can get it to jump start by unhooking the relay and using a wire to touch the positive side of the battery.
Monday, October 11th, 2010 AT 11:04 AM
WRENCHTECH
  • 20,761 POSTS
OK, you have proven that the starter is good. I'm not sure how you did that because I don't even see a relay in the circuit. It's a pretty basic circuit. Starts at the ignition switch, passes through the neutral switch and then on to the starter.
Monday, October 11th, 2010 AT 11:10 AM
