1998 Pontiac Sunfire
BURINA69
  • 1998 PONTIAC SUNFIRE
1998 Pontiac Sunfire 4 cyl Front Wheel Drive Automatic
trying to remove fuel filter. One side of filter is a flair nut no problem. The other side of filter is some kind of a clip maybe? How do I remove
Thursday, October 30th, 2008 AT 3:17 PM
LLOYDERBAUM08
  • 26 POSTS
Its a quick connect fitting. Once you get the flare end off the other side has like a white clamp sorta thing to it. The easy way is to just take a screw driver and push in on both sides and it should pop off. Dont worry about breaking it. And if anything should happen to it there not very expansive at al to replace the white clip
Saturday, November 22nd, 2008 AT 7:11 PM
