I have a 97 Pontiac Sunfire with a 2.2L engine. It has 214,000 and has run fine till last summer. Toward the end of the summer when the temperature outside was hot it started stalling. During the winter time this year it has never missed a lick. Now that spring is here and the temperature is warming up it has started doing this again. I have replaced fuel filter, both coil packs, wires, plugs. The only common denominator seems to be the outside temperature. To add to it, you can smell gas inside the car sometimes. Not sure if it is related but just wanted to tell you. The check engine light comes on and when put on a computer it gives a misfire error and other times nothing at all.
SPONSORED LINKS
Thursday, March 19th, 2009 AT 7:10 AM
