About a month ago, I ran out of gas on my way to work. Ever since then, when my tank is below 3/4-1/2 full, I have sporadic rough running and even stalling. It is usually the worst when I first start up. If the car actually stalls and quits, I have to let it sit for 3 to 5 minutes and then it will usually run fine for 10 to 20 minutes. If I keep the tank above 3/4 a tank full, I have no problems. The engine light has come on a couple of times and the error reads "running lean". I have tried some of the suggestions I have read for similar problems. I cleaned the throttle plate, I have replaced the fuel filter and checked the tank for gunk or clogged screen. As far as I can tell, everything has looked fine. I haven't had the pump itself checked and am trying to hold off going into the shop. Any suggestions?
SPONSORED LINKS
Monday, December 1st, 2008 AT 10:51 PM
